problems after changing clutch
so yesterday i and a friend change my glanza 1998 clutch since it was slipping like insane . now after changing it the abs light wont go off .. after taking the car for a spin the km/h speedometer was working . after i press the km reset button i noticed that the speedometer stayes at 0 and wont budge i checked the wires multiple times on the gearbox and also behind the dash cluster but idk seems to look good . and the abs light i don't know even why its staying on ): also should the clutch pedal be so light to push in compared to before ?
Edited by mitsuruki
probly stretched/damaged the abs wire
speedo cable not put back right in the slot on the gearbox ?? take it of there and twist by hand if the needel moves then al is ok there and just needs fitting right in the slot when screwing down
our clutches arnt ment to be light did you fit disc the right way round chunky bit to box !!!
