Had a little look at it today on my Glanza, is it difficult to do? Looks like I may have to unbolt and move the exhaust and unbolt the anti roll bar? Or can it just about he done without doing this?
Any advice or tips would be much appreciated,
Thanks.
Do the following:
-Unbolt Exhaust
-Remove 4 x 12mm bolts that hold the arb in place
-jack underneath the engine and gearbox just kind of holding it in place
-remove 14mm gearbox mount bold
-undo 5 x 17mm bolts which hold the gearbox mount bracket
-burn the rubber engine mount
Aamir
You can wiggle it out without dropping the exhaust, dropping the exhaust does give a bit of space though! I have to drop my ARB down to get to the back bolts on the mount but I have a whiteline ARB so you might get away with the standard one
