Ginge274 Posted December 14, 2014 Posted December 14, 2014 Not sure how to go about removing the airbag so I can fit my boss and quick release any help grateful Quote
nikhilkamdar12 Posted December 15, 2014 Posted December 15, 2014 (edited) 1) Start by removing the battery2) Id say leave it for a bit lol3) Then go to the steering wheel and on the left side underneath a plastic cover is a torx bolt in there you need to undo and the other side to4) The front airbag cover should come off5) You will see the airbag in there and i'm sure its held in with a few bolts, undo them and undo the yellow wire attached to it along with the yellow airbag ring that goes there as well6) You will see a big nut holding the wheel on, undo this too but don't take it off fully. Before you do take it off fully, pull the steering wheel to break it loose otherwise your gonna give yourself a nose bleed lol 7) Undo the nut fully and the wheel is now off and can proceed to fit the boss, horn and wheel Hope it helps did it some while ago so all from memory but I i'm sure its 90% accurate Edited December 15, 2014 by nikhilkamdar12 Quote
5e colin Posted December 15, 2014 Posted December 15, 2014 (edited) there is a new law out now that it will fail nct/mot about them steering weels and snapoff on airbag cars Edited December 15, 2014 by 5e colin Quote
Roachy1994 Posted December 21, 2014 Posted December 21, 2014 there is a new law out now that it will fail nct/mot about them steering weels and snapoff on airbag cars i thought you was ok as long as their isn't a airbag light on ? i maybe wrong Quote
