jayjaystarlet Posted January 16, 2008 Posted January 16, 2008 i have just got a starlet which needed new clutch got it put in could anyone tell me where the gear box oil go's and how much you put in thanks
Nanglebadger Posted January 16, 2008 Posted January 16, 2008 moved out of the photo gallery section to technical.someone will be along shortly to hep u out man. The Dark Room is the photo section of the forum, u were looking for technical.Phil.
nic1.3 Posted January 16, 2008 Posted January 16, 2008 i have just got a starlet which needed new clutch got it put in could anyone tell me where the gear box oil go's and how much you put in thanks hi mate u need about 2.5 litres of oili got one of the castrol oils available from halfrauds and got sum gbox additive aswell and its really smooth now.ok if you want to change the oil there are 3 nuts to look for on the bottom of the box there's a large nut to remove in order to drain the old oil,on the side box facing the radiator there is another nut to remove, this nut is use to show amount of oil u need to put in the box when filling it.and the nut on the top of the box is best got at by removing the cold air feed fro the stock box.so basically remove all these nutswhen the box is empty put back on the bottom nut, leave off the nut on the side.with a funnel if you have it fill the box until oil comes out where the middle nut was, u now have enough oil in it.replace the middle nut and top nut, be careful with these man as you could damage them and thats it pretty much
