Hi all,
Sorry if this is in the wrong section (not sure where to post it). But basically my petrol flap won't open, when I pull the latch I can here it trying to open but it won't open. So I removed the passenger side plastic the little one. And pulled/pushed the cable and it just came straight out. So yeah, just trying to fiquire out how I can fix this without having to open the boot and get a screwdriver down the inside to flick it open.
Phase anyone had the same problem?
Thank you
Aamir
the metal bit on the flap might be bent just pull the lever and let some1 els open the flap then bend the little metal bit that produces tension
this happens to mine all the time. What seemed to fix mine was as above, pulling the little metal bit back to where it was meant to be
Hi thanks for the replies!
I'll have a go at doing this and I'll let you know how I get on!
Thanks again
Aamir
I'll open it for you
So whenever I need to put fuel in my car I'll take you with me?
I just want it to open like normal rather than having to poke a screwdriver into the side to open it ffs :sad:
Aamir
Yeah there should be a little spring bit on the inside failing that with my first na I put a sponge in there so when I pulled the lever it opened it enough then after if you spill any you can mop it up ;)
