Hi guys, found my passenger rear caliper was sticking. Put new piston seal and all the dust boots on and the wheel turns freely, once i connected the handbrake cable back up the piston side pad seems to rub the disc and causes noise when driving. Is there a way to adjust one side of the handbrake so itll return fully or is there another issue? Cheers, Matt
yeh cable seems to release ok, just doesnt seem to release far enough. Once I take the handbrake cable from off the caliper its fine but I have to move the arm slightly to connect the cable up.
I'll take a look at it when i get a chance. Can the cable be adjusted without adjusting the pair or is it only from the front? If the spring is fine of course.
