Hi guys I recently forged my engine and it's started smoking badly. It mainly only does it when been stood idling and then I rev it and poors loads of blue smoke out then after a few revs it pretty much clears. Any ideas guys? I was wondering if maybe a stem seal has popped of or something?
I also only built engine 1400 miles ago and is spitting abit of oil out my rocker cover breather filter and can see steam come from it
Had the same on my Volvo 850 t5, have a video on YouTube of it somewhere. Will look for it!
But the cause was a worn turbo. After replacing it it was gone!
Turned out I might had a too small exhaust or a bump in it
shud be 160-170 on a normal standard turbo lump
so bearing in mind most forged pistons are lower comp I wud say around 150-160.
most importantly there should be a varient of no more than 14psi
