Rossco1991 Posted January 6, 2015 Posted January 6, 2015 Hi guys will a na 4efe gearbox fit and work in a glanza 4efte? Thanks Quote
bucketep91 Posted January 6, 2015 Posted January 6, 2015 Aye it will fit and work no problem. For a while at least Quote
5e colin Posted January 6, 2015 Posted January 6, 2015 as said above it fits and the car will pull a lot harder but loose out on a lot of the top speeds also cruising speed will go up 200/300rpm Quote
Rossco1991 Posted January 6, 2015 Author Posted January 6, 2015 Ok brill thanks guys will I need a rear mount and shafts as I have an oem lsd box in ATM? Quote
5e colin Posted January 6, 2015 Posted January 6, 2015 yep mount and longer shaft also sandwish plate between block and box is differnt mate Quote
Rossco1991 Posted January 6, 2015 Author Posted January 6, 2015 Ah ok that's cool, thanks for your help Quote
5e colin Posted January 6, 2015 Posted January 6, 2015 did the oem lsd box get fucked ????? im after some internal parts if your scrapping the box Quote
Rossco1991 Posted January 6, 2015 Author Posted January 6, 2015 No it's got a really slight crunch only when coming down the gears from 3rd to 2nd.......needs a syncro I think Quote
