Rocketbunny Posted January 24, 2015 Share Posted January 24, 2015 What's the best way to do this guys? Quote Link to post Share on other sites
akyakapotter Posted January 24, 2015 Share Posted January 24, 2015 Impact gun electric or air best way to do it Quote Link to post Share on other sites
AdamB Posted January 24, 2015 Share Posted January 24, 2015 Aye impact gun for the bolt but it may well be stuck on there, so then get a 3 legged puller to pull it off Quote Link to post Share on other sites
Rocketbunny Posted January 25, 2015 Author Share Posted January 25, 2015 Ain't got an impact gun mate :/ I've put cams in but can't seem to get the belt over the same pulley there's a tensioner but I'm pretty sure I have to take lower belt cover off to access it, can anyone think of an easier way to put the belt on?? Quote Link to post Share on other sites
FMuscle Posted January 25, 2015 Share Posted January 25, 2015 There's a small cap that lets you loosen the tensionner bolt just above the crank pulley. Quote Link to post Share on other sites
Rocketbunny Posted January 25, 2015 Author Share Posted January 25, 2015 So I don't need to remove the cover mate? Quote Link to post Share on other sites
davehart Posted January 25, 2015 Share Posted January 25, 2015 Just use a simple puller set like this: :: http://www.ebay.co.uk/itm/46Pc-Harmonic-Puller-Set-Crankshaft-Balance-Puller-Gear-Flywheels-Steering-Tool-/140848988888?pt=LH_DefaultDomain_3&hash=item20cb4102d8 No need for air tools. Quote Link to post Share on other sites
FMuscle Posted January 25, 2015 Share Posted January 25, 2015 So I don't need to remove the cover mate? Not to loosen the tensioner. Quote Link to post Share on other sites
Rocketbunny Posted January 25, 2015 Author Share Posted January 25, 2015 Cheers mate Quote Link to post Share on other sites
