ryan22laird Posted January 25, 2015 Share Posted January 25, 2015 Awryt lads can anyone help my fans constantly stays on from the minute the car starts up what causes this the air con is removed and it's got a low temp thermostat Quote Link to post Share on other sites
fremyjay Posted January 25, 2015 Share Posted January 25, 2015 Once aircon is removed it will stay on, you need to bridge the a/c connector as far as im aware Quote Link to post Share on other sites
_shaun_ Posted January 25, 2015 Share Posted January 25, 2015 That's only on the gts it should world fine on a glanza td for whatever reason make the fan run constantly if they do your engine Quote Link to post Share on other sites
fremyjay Posted January 25, 2015 Share Posted January 25, 2015 fuck knows why someone has previously cut and bodged the wires together on mine then :/ Quote Link to post Share on other sites
ryan22laird Posted January 25, 2015 Author Share Posted January 25, 2015 That's only on the gts it should world fine on a glanza td for whatever reason make the fan run constantly if they do your enginewhat do you think could be causing thid shaun ? Quote Link to post Share on other sites
ryan22laird Posted January 25, 2015 Author Share Posted January 25, 2015 Once aircon is removed it will stay on, you need to bridge the a/c connector as far as im aware a was reading this on the forum yea people was saying if the aircon is removed the fan will constantly stay on a was thinking about just running a wire to the fan and a switch inside the car so a can turn it on and off when a feel like it Quote Link to post Share on other sites
_shaun_ Posted January 25, 2015 Share Posted January 25, 2015 Am not 100% possibly the sensor or rad fan switch try trace back the wires. You can wire it on a switch I had mine on an override switch so I could put it on if I planned the kick the arse out it but as it stands it rarely ever goes on I can leave mine parked and idling with the heater on medium hear and the rad fan never comes on. Quote Link to post Share on other sites
