chrisholly Posted January 26, 2015 Share Posted January 26, 2015 (edited) Hi I needEmange blueBigger fuel injuncters for 240hp ep82 i think i need 430Fuel pressure regCluch stage 2 for w.e I need to hold 240hp ep82New or were the best place I can get?Thanks Edited January 26, 2015 by chrisholly Link to post Share on other sites
glanzatd04l220 Posted January 26, 2015 Share Posted January 26, 2015 ive a set of 370cc injectors if your interested and are direct fit. £80. kevin Link to post Share on other sites
chrisholly Posted January 26, 2015 Author Share Posted January 26, 2015 will they do the 240bhp tho? Link to post Share on other sites
Matt1878 Posted January 26, 2015 Share Posted January 26, 2015 On 1/26/2015 at 6:31 PM, chrisholly said: will they do the 240bhp tho?I'm running 237 and I'm on stock injectors. You will be fine if your running 1 bar Link to post Share on other sites
glanzatd04l220 Posted January 26, 2015 Share Posted January 26, 2015 On 1/26/2015 at 6:31 PM, chrisholly said: will they do the 240bhp tho? there good for 260/270. kevin Link to post Share on other sites
chrisholly Posted January 26, 2015 Author Share Posted January 26, 2015 (edited) oh well tuning dev said i need injectors? is this ture thn?? will it be better to have the 370s just in case then?have u got a pic kevin? Edited January 26, 2015 by chrisholly Link to post Share on other sites
Matt1878 Posted January 26, 2015 Share Posted January 26, 2015 Only if you want to run any more than 1 bar. You will need to run 1.1/1.2 bar on td04 for 250ish. If your just running 1 bar then stock is fine Link to post Share on other sites
chrisholly Posted January 26, 2015 Author Share Posted January 26, 2015 (edited) well i have a gt28r i know i had it so i fitted it im just trying to get around 230-240 what Clutch should i go for aswell? and ideas on were i can get one cheap? wishing i won the lottery right now =] Edited January 26, 2015 by chrisholly Link to post Share on other sites
glanzatd04l220 Posted January 27, 2015 Share Posted January 27, 2015 On 1/26/2015 at 6:36 PM, chrisholly said: oh well tuning dev said i need injectors? is this ture thn?? will it be better to have the 370s just in case then?have u got a pic kevin? kevin Link to post Share on other sites
Socks Posted January 27, 2015 Share Posted January 27, 2015 We have this regulator in stock:http://www.jdm-ep.co.uk/index.php?main_page=product_info&cPath=121&products_id=558 Link to post Share on other sites
