jack_wetone Posted January 30, 2015 Posted January 30, 2015 i have searched and searched i have a starlet sr ep91 with 5efe engine on standard ecu i want to try and put this ecu in that i got when i was getting a 4-2-1 exhaust mani and intake manifold and tb i beleive same as turbo and yellow/brown injectors from a ee101 4efe corolla that had no imobiliser or from what i could see it didnt it was a k reg 92 any ideas if this will work or if i can make it work and what does the green label mean ? it is quite a bit bigger my starlet ecu is 2/3 the size of the corolla one. any help apriciated thanks Quote
daniel_g Posted January 30, 2015 Posted January 30, 2015 Firstly do they have the same plugs ?Put a couple pics up to compare.Did you take both manifolds and injectors etc from the corolla ? If you bolt that lot on the 5E should be pretty decent Quote
jack_wetone Posted January 31, 2015 Author Posted January 31, 2015 (edited) hi thanks for the reply and yes the plugs are the same it wont let me post a pic so here is a link to my fb https://www.facebook.com/photo.php?fbid=895836477104859&set=pcb.895836583771515&type=1 and i did plug it in today and it just start for like 1 second and cuts out ? Edited January 31, 2015 by jack_wetone Quote
Trevstar34 Posted March 9, 2016 Posted March 9, 2016 (edited) Probably too late now, but this means it's attempting to start but isn't reading the correct signals, you'll need to open up both ecus and compare the pin-outs printed on the circuit board, maybe (and I mean maybe) it could be a matter of swapping around some wiresBut certain 4e & 5e engines have different types of ignition systemsAs for immobiliser, again you'll need to check the board for 'imi' and 'imo', if it doesn't have it printed on the board, then it probably won't have an immobiliser, and it should still start however immobiliser won't be functional But don't quote me on it Edited March 9, 2016 by Trevstar34 Quote
