ok lads I failed the test 2nd time to night. After I failed the first time i replaced the two handbrake cables going to the caliper and i changed the pads and cleaned the discs.I seen before the test when i was tighten up the handbrake i rang out off thread so that might be it.I will rebuild the calpers again as i only did them last year and i will get a new cable from the hand brake to so all 3 cables will be new. is there anything i am missing lads?
This is from first test
And this is from the 2nd test today
any ideas lads
Thanks
get those pistons pushed out and cleaned up and check the seals. its not far off passing but the imbalance is high so maybe its just one calliper causing your problem.
Ok lads I was working on the glanza there. when i drive the car up the drive way 5kms and pull the handbrake the passenger side skids locks up but the drivers side still moves.when i jack up the rear wheels and have handbrake on full i cannt move both sides will that pass nct?
The more i tighten the handbrake cable in the car the worse the drivers wheel gets icon_scratch.png icon_scratch.png
I had a look at the equaliser and it looks good and straight do i have to do adjustment to that?
I adjusted the piston on the caliper by hand by moving the piston in with the lever for the handbrake cable with a flathead screwdriver is this right? The handbrake cables were disconnected at the time.
lads any help please
Edited by glanzadude
Any luck on fixing this... I just back from Oz and getting the car up and running and got caliper rebuild kit. I reckon I going to be in same position as yourself for the test. You buy new handbrake cables ?
Ah ok I have a mate in Toyota will be on to him in morning for a price!!! I take it that was for the 3 yeah, I'm whipping off the rear calipers tomorrow to rebuild them so got the kit for €50 from Toyota
