Harikei Sunko Plug & Play ECU
EP91 Glanza V Harikei Sunko Plug & Play ECU
Rare Plug & Play ECU, connect it up, turn the key and away you go.
No Remapping Required. Fuelling Check Recommended.
Raised Rev Limiter to 8000rpm+
Removes 180kph Speed Limiter
Removes Over Boost Protection Limiter
More Aggressive Fuelling & Timing
Capable of 200bhp+
Designed for Stock 4E-FTE Engines & CT9 Based Turbochargers
only £449.95
Click here to buy now!
  • 2 weeks later...
