Socks Posted February 2, 2015 Posted February 2, 2015 RX7 Intercooler Conversion RX7 Intercooler Conversion Want more power, but not more Lag from a Front Mounted Intercooler Kit? The RX7 Big Top Mounted Intercooler Core Conversion is the way to go. Much bigger and thicker intercooler core, gives additional power, with no added lag! only £59.95 Click here to buy now! Quote
toyotag2014 Posted February 22, 2015 Posted February 22, 2015 Might be a stupid question but with this can you put the standard glanza intercooler cover on it? Quote
toyotag2014 Posted February 22, 2015 Posted February 22, 2015 Ow that's a shiter what exactly does this intercooler do compared to standard I'm not looking for more power I just want engine to be as healthy as it can get sorry for the spams Quote
Socks Posted February 22, 2015 Author Posted February 22, 2015 Bigger the intercooler. The lower the charge temps.Colder the charge temps. The more dense/more oxygen there is in it.More Oxygen & More Fuel.... More Power... Getting rid of ANY Heat is a good thing for an engine tho! Quote
toyotag2014 Posted February 22, 2015 Posted February 22, 2015 So I can run this and keep standard power would I have to change or buy anything else to run this? Quote
Socks Posted February 22, 2015 Author Posted February 22, 2015 This is a kit/direct fit. It is bigger then the stock intercooler. You will get more power by fitting, as it will lower the charge temps.. Good though, if you dont want to cut your car up to fit a front mounted intercooler! Quote
toyotag2014 Posted February 22, 2015 Posted February 22, 2015 Kl thanks socks I will get back to you about this Quote
