It seems the tire presure does not appear to be on the door panel on my beast which is a pain in the ass n the handbook only lists the standard tire presures...
So anyone happen to know the tire presures for an SR with the standard speedlines n tires on?
Any help much apreiciated :unsure:
Please don't post technical car related topics in the General section in future please :unsure:
The Technical Discussions section is for that and caters to all your needs.
Have a good look in the tech section to see if it has been covered before posting a new topic or do a search > Tyre Pressures.
This saves the same topics being created over and over. All it takes is a quick search.
Cheers
Joz
  • 2 weeks later...
i keep mine at 33 psi hot.
remember, actual pressure is different to what it is when you fill it up. go for a blast then check the pressure. it will be different to what you put in..
