Starletsr98 Posted February 4, 2015 Posted February 4, 2015 Has anyone cut the center of the bumper so the numberplate part is missing Quote
FMuscle Posted February 4, 2015 Posted February 4, 2015 I did a few cuts, the whole thing is not missing but the part where the plate bolts to is. Why? Quote
mikey4410 Posted February 4, 2015 Posted February 4, 2015 same as above.removed a bit under the plate and relocated the bolt holes and that as far as I went. Quote
Starletsr98 Posted February 5, 2015 Author Posted February 5, 2015 Im thinking of removing all of it and want to see how to cut the bit that goes onto the sides of the bumper as it curves onto it Quote
Starletsr98 Posted February 8, 2015 Author Posted February 8, 2015 Have you got a better pic in the daylight mate, from what i can see its what i will end up doing it looks good Quote
mikey4410 Posted February 8, 2015 Posted February 8, 2015 relocated the numberplate bolts and fitting points. hope this helps you Quote
Starletsr98 Posted February 8, 2015 Author Posted February 8, 2015 Wow thanks for the help mate its much appreciated Quote
