Can anyone help me on a small problem that I have noticed when I put my foot down I get a vibration through accelerator pedal? Anyone else had this on there glanza v? What could this be? Thanks
check the throttle cable on the pedal and on the throttle body to make sure its not over tight, also check the bolt that holds the pedal in place, wd40 wont don't any harm :thumbsup:
It has had new wheel bearings & CV boots done though just before I bought the car, it's an odd one its ok at first then starts to do it after I have drove it for 1 or 2 miles low bust its normally fine 9 times out of 10 but in high boost you feel it more if I put my foot down. When I bought it the person said to me there is no need to drive it in high boost, lol
only mentioning it because I had a similar feeling through my pedal, got worse the faster the car travelled and ended up being both my inner cv joints going because my mount had perished....just a heads up bud
might be a that then, as when I bought the car I got told it has just had new CV boots. Cheers Edited by mart1
