1bar ct9 with p&p ecu
Would recommend running a wideband as well to check your fuelling mate.
People only really started banging on about these from last year before that I never seen it mentioned as an importance but yes there good bit of kit, never seen any in the old jap books I will purchase one, one day I believe they come stock in some modernish scoobies
Very useful bits of kit. Gained popularity over the last few years as there cheaper now. Most setups are fine yeah but always worth being able to keep an eye on fuelling. Especially on full boost/throttle!
Makes sense :)
Get it checked out with det cans and a wideband at least, mine used to run fine most of the time with a JAM pnp ecu, but on some occasions of WOT the afr was as low as 9.5, which is stupidly rich, it ran better with a TD04 to be honest
What's the safe afr figure, read 13 somewhere?
