Hello all
Does anyone know on what the gear ranges are in terms of what kph or mph i can do in each of the 5 gears. Please state the full range for a standard Glanza V Turbo, whether is in high or lo boost and if your stating mph or kph. For example, on my previous 1.1 litre Ford Fiesta mark 3 they were as follows as stated in the original manual. (Please note these are the absolute minimum and maximum speeds the car could've have been driven in each gear.
1st gear: 0mph - 21mph
2nd gear: 3mph - 41mph
3rd gear: 15mph - 60mph
4th gear: 21mph - 82mph
5th gear: 24mph - 101mph
Many thanks
dont know why you want to know this but this is what my n/a does to give you a rough idea
1st- 30mph
2nd- 58mph
3rd- 85mph
4th- 108mph
5th- 120ish?
hope that helps a little
1st- 30mph
2nd- 58mph
3rd- 85mph
4th- 108mph
5th- 120ish?
Many thanks
Was curious just to know, thats all :)
Ford Fiesta 1.3 Endura
1st - 25ish MPH
2nd - 55ish MPH
3rd - 78ish MPH
4th - 90ish MPH
5th - 89ish MPH :)
Starlet N/A
1st - 28 MPH
2nd - 59 MPH
3rd - 87ish MPH
4th - 109 MPH
5th - 112 MPH (It can't be bothered to go any faster ;) )
These are all on flat road.
Remember the speedo isn't accurate though. I've heard the N/A Starlet limits at 55mph in second accurately, not sure about other gears though.
  • 2 months later...
download a gear ratio converter graph thing and google ep82 and ep91 gear ratio's. I got it on here a lifetime ago, easy to use and you can change your final drive ratio too.
Search on here first "found some gear ratio's"
