Jay2ohh Posted February 15, 2015 Share Posted February 15, 2015 yooooon a ct9 turbo, the oil feed that has the banjo ring fitting with the bolt that ... well bolts it to the block (braided oil feed pipe etc that one)what size is the banjo ring? the hole what the bolt goes through? Quote Link to post Share on other sites
akyakapotter Posted February 15, 2015 Share Posted February 15, 2015 yooooon a ct9 turbo, the oil feed that has the banjo ring fitting with the bolt that ... well bolts it to the block (braided oil feed pipe etc that one)what size is the banjo ring? the hole what the bolt goes through? Think I have one of those in my engine set will measure it later when I finsh work. Quote Link to post Share on other sites
mikey4410 Posted February 15, 2015 Share Posted February 15, 2015 http://www.ukstarletowners.com/topic/87104-turbo-oil-feed-banjo-bolt-size/ Quote Link to post Share on other sites
