Ollieh17 Posted February 17, 2015 Share Posted February 17, 2015 What have people used to connect the extra cable to relocate the battery in the boot to the original wiring? Quote Link to post Share on other sites
_shaun_ Posted February 17, 2015 Share Posted February 17, 2015 The first time I used a maxi fuse holder and stripped the oem battery terminal off which leaves you with just a square connector. I've just rewired Mine and now the fuse is on the battery side and that same square connector is on a battery kill switch Quote Link to post Share on other sites
Ollieh17 Posted February 17, 2015 Author Share Posted February 17, 2015 Ive seen people use a circuit breaker in the engine bay which can then be kinda used as a killswitch. My plan was like yours to have fuse/breaker on the battery side though. So i could effectively join the wires with the OEM connector and a kill switch? Quote Link to post Share on other sites
_shaun_ Posted February 17, 2015 Share Posted February 17, 2015 Aye from memory the battery terminal just unbolts and I trimmed some extra metal off. The whole was like a MM to small so I just filled it slightly and it bolted straight on Quote Link to post Share on other sites
