Hello
I'm just wondering if anyone has used a multimeter when checking certain things to rule things out, I have a slight misfire on idle at the moment like a little hiccup every maybe 10-20 seconds, so I got myself a multimeter just to check a few things
Have new plugs going in Saturday aswell
I know the injectors need to be 14.9 ohms
Need to check the ht leads and coil with the multimeter, just wondering what figures I am looking for please.
Thanks Pat
Edited by patman
You could pull the leads out and visual check first when mine ran jerky the spark actually put a hole in the side of the lead yeah always good to replace plugs often anyways.
Hello Gainzy Thankyou for the tip I will do this aswell, it's only on idle when driving around its all good but only up to 3k at the moment due to new full rebuilt so still running it in
If it only occasionally and slightly misses at idle its not really anything to worry about. I'd check the resistance of the leads and make sure there isn't one thats majorly different (they will all vary due to the length). Check the condition of the rotor and dizzy cap. Also check the primary and secondary resistance of the coil. If its not doing it when driving its a fair bit harder to track down. What fuel are you running? Whats the base timing set at?
Hello stu Thankyou so much for the help there, I've decided to put it in a garage on Saturday good friend of mine and there gonna test everything I have a feeling it could be te coil just hoping it isn't anything to serious, also I put in 97 unleaded, never had 95 in the car but Thankyou so much for your help once I get told the problem will post on here 👍
