Side port to vacuum, ideally as close to the turbo compressor housing as possible,
Top port to an EBC solenoid if you run one, if not, leave the top port on the waste gate open.
Matt
I run mine as below
Will also depend on what Boost Controller you are running in regard to set up of hoses, i run the Blitz SBC and both lines run to the dual solenoid with a T piece off to the Turbo
Was the question in regard to the fittings on the MVS??
John
