Patches Posted February 25, 2015 Posted February 25, 2015 Does anyone know what boost kit is for the apexi power fc for EP91? Lots of contrasting information online about where the map sensor and boost solenoid get fitted and which one to buy http://www.rhdjapan.com/apexi-power-fc-boost-control-kit.html Quote
pockrockgtti Posted February 25, 2015 Posted February 25, 2015 It depends on the model. If u look on the side of the ecu ull seea little port 3pins or 5pin. If it has 3 pins you buy the optional 3 pin harness. The harness plugs into the port, u plug the optional map sensor into the harness. and wire the boost solenoid into the oem solenoid wires. Quote
Patches Posted February 25, 2015 Author Posted February 25, 2015 (edited) It depends on the model. If u look on the side of the ecu ull seea little port 3pins or 5pin. If it has 3 pins you buy the optional 3 pin harness. The harness plugs into the port, u plug the optional map sensor into the harness. and wire the boost solenoid into the oem solenoid wires. Pretty sure its the 5-pin i've got, will take pictures and upload them when i get home. If its the 5-pin will it work the same way? boost solenoid in the stock loom and map sensor into apexi harness and to the side of the ecu? EDIT: its a 3 pin i've got. I'm guessing if the apexi map sensor plugs into the side of the ECU then the stock map sensor can be removed or will i need to wire in the apexi map sensor in the stock location? Edited February 25, 2015 by Patches Quote
