So, I was checking but there is little to no information on the 1E, I'd like to know where these are located and if somehow I can rewire a 4E-FE speed and temp sensor to work with the EP70 cluster (the car wil be running a bike carbed 4E so no ECU at all) :)
Just swap the 1e dash temp sensor onto the 4e in place of its dash temp sensor. They are located on the thermostat housing for both engines - single pin sensor. By swapping the 1e sensor onto the 4e your making sure the dash gauge reads correctly as some temp sensors have different resistance ranges.
By speed sensor are you meaning the speedo drive? Just run the stock 1e one into the 4e gearbox.
