EP70-PT Posted February 28, 2015 Posted February 28, 2015 So, if I want to swap a 1E with a 2E, can I use the 1E dizzy so I don't have to remove the coil and all that from the stock EP70 ignition ? Does it work? If not, does the 2E dizzy have a built in coil and is it just a matter of wiring 12V ignition and ground and connect the existing wires to the condenser? Quote
5e colin Posted February 28, 2015 Posted February 28, 2015 should be a strait fit atleast can be made to fit Quote
EP70-PT Posted February 28, 2015 Author Posted February 28, 2015 should be a strait fit atleast can be made to fit If I want to use the 2E dizzy, is it just a matter of wiring +12V ignition and ground? Quote
5e colin Posted February 28, 2015 Posted February 28, 2015 think i got confused there use your 1e dizzy in the 2e so your keeping stock electronics are you going from carb to injection ?? Quote
Stu Posted March 1, 2015 Posted March 1, 2015 The dizzy's are inter-changeable so use which ever one you want. Ideally you would use the dizzy setup with the inbuilt coil as its an electronic setup not a points style pickup and its works better. Quote
EP70-PT Posted March 1, 2015 Author Posted March 1, 2015 The dizzy's are inter-changeable so use which ever one you want. Ideally you would use the dizzy setup with the inbuilt coil as its an electronic setup not a points style pickup and its works better. Thanks man, I think I'll keep the 1E one, make it simple Quote
