EP70-PT Posted February 28, 2015 Posted February 28, 2015 So, I'm toying with the idea of swapping a 1E with a 2E as I can find them for like 300€ with everything, What I've been able to find is that the 2E dizzy has a built in coil and needs to be wired but apart from that, is it just plug and play? Also, the 2E will have bike carbs, found a cheap set of good condition carbs ^^ Quote
mccartney11 Posted March 6, 2015 Posted March 6, 2015 Just bolts your own stuff on, swap dizzy,Inlet and carb and fuel pump and away you go man Quote
