Flower Posted March 1, 2015 Posted March 1, 2015 Hi guys,Bolted on a WEPR TD04 set up SS and EXWG setupSeems idle afr'a are around 11 which I can live with would like to see it leaner if anyone has any ideas ? Although I have had a new lambda.Also I cruise the afr seems to bounce from 14.5 to 16-17 it's really confusing me ? I know the pnp ecus arnt the best but I do have a emanage blue to go on. It is a auto converted to manual so it has a 4 wire tps could this affect it ?Also wot is well up there at around 10-10.5 Any advice would be great ? Cheers Quote
mikey4410 Posted March 1, 2015 Posted March 1, 2015 I know for a fact that afrs are these at set condition : cold start 11.5 afrwarm idle 14.7-16.00cruise and light loads 14.7-15.00boost wide open throttle 10-11.5 depending on your tune its sounds asif ure cars thinking its "cold" abd its fueling for it. Quote
Gainzy Posted March 1, 2015 Posted March 1, 2015 Just put the stock ecu back on run low boost sell the plug n play and go get it fine tuned no more afr worries... Quote
5e colin Posted March 1, 2015 Posted March 1, 2015 try swapping over to a new ecu temp sensor and o2 sensor they both affect it Quote
