As above, was fine off the car, timing all checked.starter motor removes and in neutraland still wont turn. Defo turned over before gearbox clutch flywheel etc were fitted. Cant remember if i turned it over after fitting.
Update took the plug out and dropped some oil down the bores. Turns over know up until one point, which happens every 1 revolution of the crank pulley
Edited by Ollieh17
Timings fine.... Strange one. Reckon it seized tbh from being in the car not running. Took plugs out and dropped oil down the bore and it budged then
Tbh..no i havent mate. Didnt really think about it. I hope so, though this time i dont think ill be that lucky. May have to be a fordged engine time haha
I had this on the forged engine, turned out the oil pump and pistons where fucked. You replaced the oil pump?
Not exactly sure what was causing it though
Had another go turning it over after a bit of wd40 down the bore. While doing this i had a listen to the gearbox flywheel end and diffently some sort of rubbing noise coming from that area. Which is a relief i guess
Yeah, if you've got a bent sandwich plate it'll push against the flywheel hence making the engine hard to turn over! Hopefully that'll solve your problem!
Found the issue, cusco clutch and spec 6 combination meant the clutch rubbed on the bellhousing. Had to grind some of the clutch and bellhousing back
