ashep91 Posted March 6, 2015 Posted March 6, 2015 Hi does anyone know if the apexi power fc can be used with airflow meter so are they dejecto or ejecto? I don't know what it means a mapper near me wants to know Quote
pockrockgtti Posted March 6, 2015 Posted March 6, 2015 Nearly all of the powerfc (certainly the ones modified by ap engineering)for starlets are djetro units that use a map sensor. There are one or two hrf units that are ljetro and use an airflow meter Quote
ashep91 Posted March 6, 2015 Author Posted March 6, 2015 A local mapper will only map something that uses air flow meter don't know why any ideas on what ecu to go for? Quote
Phil Posted March 6, 2015 Posted March 6, 2015 A local mapper will only map something that uses air flow meter don't know why any ideas on what ecu to go for? Wont map using a MAP sensor? go somewhere else, what a pleb that fella must be. Speak to tim at tbdevelopments and find out who he uses. the EMS stinger i have forsale is ready to rock, map sensor/loom/wideband the heap. Phil Quote
