my car is a starlet with a 5efe in it and powered by 4efe ecu with rev limit of 7200rpm.
i want to install Bee-R rev limitter. Though i hv installed it following a diagram form this forum and it works. but the problem
is,
1) it gets pass by the limit which i have set in the limiter when i full throttle it.
2)The car jerks when on the go while cutting rev.
is these normal?? and it doesnt shoot flame or fart as it should.
here is my ecu pinout
Connector A
1) IPV
2) NSW (neutral start switch)
3) THW (water temp)
4) PIN (vacuum sensor)
5) THA (intake air temp)
6) IGT (ignitor)
7) IGF (ignitor)
8 )
9) NE- (distributor)
10) OX (O2 sensor)
11) STA (cranking)
12) #10 (injector)
13) E01 (earth)
14) DISC (idle control valve)
15)
16) E2 (output voltage to senssors)
17) PSW (tps)
18) VC (vacuum sensor)
19) IDL (tps)
20) SEL (for air con econ/auto)
21) NE (distributor)
22)E21
23)
24) E1 (earth)
25) #20 (injector)
26) E02 (earth)
Connector B
1) +B1 (through EFI relay)
2) BATT (from IG1 key position)
3) CCO (from exhaust temp switch)
4) FC (fuel pump relay closed)
5) ELS1 (lights on)
6) AC2 (a/c on)
7) TE2 (to check connector)
8 ) TE1 (to check connector)
9) +B (through EFI relay)
10) W (check engine light)
11) EGW (exhaust temp warning light)
12) AC1 (air con on economy)
13) SPD (from speed sensor)
14) ACT (to a/c)
15) ELS2 (rear demister on)
16) VF (to check connector)
the connection for Rev limitter i used is :-
Black---->24 on connector A
Green---->21 on connector A
Yellow---->7 on connector A
and Red---->9 on connector B
is the wiring ok??? and what might cause the problem??
Edited by Adeeb1395
thank you for the diagram. these thing shows some differences.
my black wire is connected to pin no 24 and the diagram shows that it should be connected to pin no 13
but both of them are earth/grounding. so should i change it??
my yellow wire is connected to pin no 7 and the diagram shows that it should be connected to pin no 8
but the pin in my ecu is blank which is no 8. what do u suggest to do??
Thanx in advance
