Hi
Just fitting a Prosport boost gauge and when you start the car up the gauge goes through the start up sequence but then sits there flashing at me. I followed the sketchy instructions but they aren't great, found a few bits on the net that suggested it's not getting any signal from the sensor or it has a faulty harness, so my next question is has anyone seen this or have an idea what to do? We just came straight off the inlet manifold by the way not sure if that is right or wrong?
Any help appreciated
Cheers
We have got a ready off of somewhere but not sure if that's right. Where should we be taking the vacuum lines from?
Thanks
First things first have you just got the prosport boost gauge or others? I have prosport boost oil pressure and oil temp and I know what the flashing is all about can I just ask to confirm is it when the car is actual running or just when you turn the ignition on?
