Bug679 Posted March 23, 2015 Posted March 23, 2015 Anyone got a tutorial about rebuilding a Glanza gearbox ? Can't find anything Quote
daniel_g Posted March 23, 2015 Posted March 23, 2015 You need various pullers, a vice and a hydraulic press etc. fairly specialist job.Whats exactly wrong with yours and what do you want to replace ?Theres a PDF on google but its not a step by step as such its a service manual for Techs. Might be useful though. Quote
Bug679 Posted March 24, 2015 Author Posted March 24, 2015 Hey thanks, am looking to replace the input shaft bearing but I can't get the gears to budge,is there a trick to i? I replaced one in a civic before and the gears just lifted out. This has me puzzled Hey thanks, am looking to replace the input shaft bearing but I can't get the gears to budge,is there a trick to i? I replaced one in a civic before and the gears just lifted out. This has me puzzled Quote
morgey Posted March 24, 2015 Posted March 24, 2015 One gear has bolts in it to attach a puller too the other one you need a very good set of pullers to get off.Be careful though as you can chip the teeth very easily Actually that might be the clutch hub that has the holes in it for the puller Quote
Bug679 Posted March 24, 2015 Author Posted March 24, 2015 Hmmm might jus get a replacement box for the meantime 😃 do you know does a gt box fit ? Or do you need gt mounts as well ? Quote
