jellybaby Posted April 9, 2015 Posted April 9, 2015 hello all I have a auto tb I am in the need to check if the tps is in the correct position but I am not sure what pins to clip on to as there are 4 pins instead of the 3 pin manual one. any advice or info would be helpful please kind regards Quote
FrozenJakalope Posted April 10, 2015 Posted April 10, 2015 http://www.lcengineering.com/LCTechPages/pdf/Throttle%20Position%20Sensor%20Adjustment.pdfIt's for a different engine but the TPS is set up the same way. Quote
