morgey Posted July 29, 2015 Share Posted July 29, 2015 Put a stock pressure reg on it 1st.Check the timing. Turn the crank so the bottom pulley is at 0 on the cover and whip the top cover off and make sure the top one is lined up with its marker, if that checks out take the cam cover off and check the inlet cam is lined up correctly. The 2 gears have marks on them that should be pointing at each other. Quote Link to post Share on other sites
JDMfreak Posted July 29, 2015 Share Posted July 29, 2015 stick a stock fpr on it its probably over fuelling the car making it hard to start and causing it to blacken the plugs Quote Link to post Share on other sites
starlet Craze Posted July 30, 2015 Author Share Posted July 30, 2015 Ok cool ill try that Quote Link to post Share on other sites
