Bug679 Posted April 18, 2015 Posted April 18, 2015 Hey peeps 😃 am fitting my td04 next week and will be using apexi safc, rrfpr, and fcd. What am looking to know is will it be ok to drive it to the mapping place (westwardeng) in Meath, it's about an hour and half drive from me. I'll keep it out of boost and snail it there or would it be safer to trailer it ? Are there any settings for fcd and rrfpr to drive it sorta safe there ? Thanks in advance 😃👍 Quote
akyakapotter Posted April 18, 2015 Posted April 18, 2015 Drove my forged motor with billet hybrid set up on old map for a month then to td will be fine if you stay out of boost Quote
Bug679 Posted April 18, 2015 Author Posted April 18, 2015 Cheers mate 👍 would just be nervous about doing damage on way down. Just one question would a wideband be necessary straight away ? Bit of a budget for now 😃 Quote
karl. Posted April 18, 2015 Posted April 18, 2015 Just plumb the fpr into the return line and set it to off then Fit the fcd and set it at 12. I'm not sure about the safc most likely just fit it and turn it off? Quote
akyakapotter Posted April 18, 2015 Posted April 18, 2015 Cheers mate 👍 would just be nervous about doing damage on way down. Just one question would a wideband be necessary straight away ? Bit of a budget for now 😃I don't have a wideband mine was fine mate down a good 1000miles off boost. Quote
Bug679 Posted April 18, 2015 Author Posted April 18, 2015 (edited) Ya I'd say that's the way to go alright. I'll have to post the results anyway and I'll let Yas know how it goes. Hoping for good power about 200 I'd be very happy with 😃 cheer for the help guys Edited April 18, 2015 by Bug679 Quote
Ollieh17 Posted April 19, 2015 Posted April 19, 2015 I ran 0.8 bar on a td04 on a glanza standard ecu fine.(wideband installed) just unplug/ switch off tge fcd and safc until mapped Quote
Bug679 Posted April 20, 2015 Author Posted April 20, 2015 Cheers lads. Also what pressure should I set the fpr at from what I read 3 bar should do ? Quote
Charlie28 Posted April 20, 2015 Posted April 20, 2015 2.4bar is standard fuel pressure. Just set your FPR to that until your mapped. Quote
