Charlie28 Posted April 19, 2015 Posted April 19, 2015 Anyone know where this pipe goes? Middle on bottom of throttle body, seems to be a quite long pipe?Cheers,Charlie Quote
Glanza-Ben Posted April 19, 2015 Posted April 19, 2015 To the pipe that goes to water pump just under unlet i believe Quote
jellybaby Posted April 19, 2015 Posted April 19, 2015 http://www.toyotagtturbo.com/forums/showthread.php?67023-Throttle-Body-Pipes-* Quote
Charlie28 Posted April 19, 2015 Author Posted April 19, 2015 Ok it's a vac pipe. But where does it go? Quote
Charlie28 Posted April 19, 2015 Author Posted April 19, 2015 Actually it's pipe 3 so it's water Quote
jellybaby Posted April 19, 2015 Posted April 19, 2015 Ok so it will go on the pipe on bk of the engine connected to the water pump. Or it willGo toThe thermostat housing Quote
Charlie28 Posted April 19, 2015 Author Posted April 19, 2015 Sorted now. Next problem is injectors not firing! Quote
