EPDamo Posted April 23, 2015 Posted April 23, 2015 Hi guys. Just wondering what setups people are running for hard driving. Went out for a quick blast night and had a bit of brake fade, got out and when I checked they were glowing red hot!!! Anyone else suffer from this? Cheers Quote
mikey4410 Posted April 23, 2015 Posted April 23, 2015 1.get some new front discs2.mintex 1155 front brake pads3.most important is to nenew ure old fluid for brand new dot 4 fluid.flush entire system through thouroughly and that will also make a huge difference.I have done the above and its changed my brakes so much its mad.ahh and also forgot to add, braided lines are a must. Quote
Ollieh17 Posted April 23, 2015 Posted April 23, 2015 Braided lines all round, abs removed with braided lines, wms 110% disks, greenstuff pads (shit, go for something else)toyota dot 5.1 fluid. Thats my current setup and expecting it to be fine for a bit of fast road and maybe a track day or two Quote
mikey4410 Posted April 23, 2015 Posted April 23, 2015 I am doin brands next wed eve so will let u know how my setup holds up. Quote
Keri-WMS Posted April 23, 2015 Posted April 23, 2015 The advantage of our 110% discs over every other OEM fit disc I've seen is the extra thermal mass, physical stiffness and cooling rate from the larger casting - this means for the same energy input you get a lower tempurature (this applies no matter what pads you use, how you drive or if the discs are grooved or not). Quote
AdamB Posted April 23, 2015 Posted April 23, 2015 Make sure the calipers aren't seized or binding. Quote
