Matt1878 Posted April 25, 2015 Posted April 25, 2015 Brilliant advice Leave the top port open and run the vac line from the side port on the waste gate, to a boost source ideally your turbo compressor housing. That will then run it off spring pressure. You only use the top port aswell when running with an EBC so don't use it for the moment to rule that out.Ooh yes it is a side port!! Not a top.. Sorry, had a beer this evening! Lmao. Cheers Rob. Glad it's sorted anyway! Quote
RobSR Posted April 25, 2015 Posted April 25, 2015 Okay well at least that shows some of your settings / your Boost controller / solenoid is the issue then. Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Hmmmm. It worked on the actuator. Low was. 8 and high was 1.1. Only thing i cant see. Where does it vent from Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Ok so i found a manual and this is how ita telling me to do it Quote
