Im in need of the bottom cam-belt cover and the bracket for adjusting the power steering pump.
the bracket i am referring to has the two nuts to adjust the rod up or down. this then holds the pump in place! :thumbsup:
mine has seized solid and i am unable to free it off!
i did look on your website but was unable to find any!
thanks in advance!
Is the bracket seized or in serviceable condition? if its ok could you send it combined shipped with my 02 sensor i ordered this morning?
I know the cambelt covers are usually prone to distorting due to heat, i assume this one is in good condition? this looks as though the bottom pulley has been catching it?
thanks
Bracket: We make sure there free. If there not we scrap them, so don't worry :) I will double check its free though before shipping to you!
Lower Cambelt Cover: I haven't seen 1 lower cambelt cover that hasn't got the rubbing marks or isn't slightly warped. However it is not cracked or chipped!
If you want a brand spanker, better get off to Toyota :)
Postage Wise...
The Bracket is Heavy and the Cambelt cover is big and fragile...
So postage wouldn't be any cheaper!
Thanks Matt! I'll have the bracket if it's not seized but I'll leave the cover mate! I'll buy over on the website :)
Edited by Sefton-EP91
