turbominicooper Posted May 2, 2015 Share Posted May 2, 2015 guys and gals, i did a compression test on my 5efhe today in preparation for turbo'ing and putting in my GT. the test was done WOT and the first number is based on 4 revs/turns of the key, the other is max reading. Piston 1 - 160psi (max = just under 200psi)Piston 2 - 145psi (max = 170psi)Piston 3 - 150psi (max = just under 170psi)Piston 4 - 90psi (max = 105psi) My plan was high compression td04, i take it number 4 needs sorting - what about others? cheers Quote Link to post Share on other sites
5e colin Posted May 2, 2015 Share Posted May 2, 2015 piston 4 rings or valve seat issue why not fit 4efte pistons to them rods ???? be so much better i would like them nrs to be closer indeed Quote Link to post Share on other sites
turbominicooper Posted May 2, 2015 Author Share Posted May 2, 2015 piston 4 rings or valve seat issue why not fit 4efte pistons to them rods ???? be so much better i would like them nrs to be closer indeed need to keep my 4e as a built unit to transfer back in the sera. im thinking set of bigger pistons and get block bored, but that means id lost the high compression ive wanted Quote Link to post Share on other sites
yaristurbo Posted May 2, 2015 Share Posted May 2, 2015 Have you worked out how much you would lose from over bore? Quote Link to post Share on other sites
mikey4410 Posted May 2, 2015 Share Posted May 2, 2015 ahh man.sorry to see this :-( Quote Link to post Share on other sites
5e colin Posted May 2, 2015 Share Posted May 2, 2015 set of 4efte pistons can be got very cheap amigo no nead for over bore just hone the block urselve fit used pistons with new rings you will be able to run more boost on the 4efte pistons then on the 5efhe 1s anyways its a no brainer going to 4efte pistons can be converted really cheap Quote Link to post Share on other sites
turbominicooper Posted May 2, 2015 Author Share Posted May 2, 2015 set of 4efte pistons can be got very cheap amigo no nead for over bore just hone the block urselve fit used pistons with new rings you will be able to run more boost on the 4efte pistons then on the 5efhe 1s anyways its a no brainer going to 4efte pistons can be converted really cheap and what about going 74mm flat tops for example?? Quote Link to post Share on other sites
5e colin Posted May 2, 2015 Share Posted May 2, 2015 wich 1s forged ??? dont bother in 74mm if so go bigger with a rebore but they wont fit on the 5efhe rods because floating vs press pin style Quote Link to post Share on other sites
turbominicooper Posted May 2, 2015 Author Share Posted May 2, 2015 looks like the 4efte pistons are for the win then with some oversized rings? Quote Link to post Share on other sites
AdamB Posted May 2, 2015 Share Posted May 2, 2015 There shouldn't be anymore than 1 bar / 14.5 psi difference between cylinders. You can do a leak down test which is more accurate and will tell you where the engine is losing gas. Regarding pistons, I know you say you don't wanna loose the high compression, but flat tops in a turbo motor are a bad idea as they retard the flame front. Quote Link to post Share on other sites
5e colin Posted May 2, 2015 Share Posted May 2, 2015 looks like the 4efte pistons are for the win then with some oversized rings? no stock size rings amigo !!! have a set of 4efte pistons tucked away i think ??? get 5efe rings on egay or local moterfactors ( 4efe ) Quote Link to post Share on other sites
turbominicooper Posted May 2, 2015 Author Share Posted May 2, 2015 whats the going rate for a set 4efte pistons anyway? Quote Link to post Share on other sites
5e colin Posted May 3, 2015 Share Posted May 3, 2015 depends on condition 50/75 pounds i think Quote Link to post Share on other sites
turbominicooper Posted May 3, 2015 Author Share Posted May 3, 2015 cheaper the better gonna get the rebuild kit and rings from speedvision, comes to £330 posted - good price for what you get i think Quote Link to post Share on other sites
5e colin Posted May 3, 2015 Share Posted May 3, 2015 what u getting in the package seems very dear Quote Link to post Share on other sites
turbominicooper Posted May 3, 2015 Author Share Posted May 3, 2015 http://www.speedvisioncps.com/index.php?main_page=product_info&cPath=40&products_id=140&zenid=8b01779f2145226e6837f4cfad643857 Quote Link to post Share on other sites
5e colin Posted May 3, 2015 Share Posted May 3, 2015 (edited) amigo i would source them parts on ebay uk it will be cheaper then buying that and paying postal and import tax go and have a chat in your local moterfactors !! al parts will do spuriouse but but the gasket from toyo or have a look in this link and check the parts in his shop :) http://www.ebay.ie/itm/TOYOTA-STARLET-GLANZA-V-EP91-4E-FTE-HEAD-GASKET-MADE-IN-JAPAN-OE-/301552708087?pt=LH_DefaultDomain_3&hash=item4635f129f7 Edited May 3, 2015 by 5e colin Quote Link to post Share on other sites
