aleximport25 Posted May 5, 2015 Posted May 5, 2015 Hello all My oem lsd gearbox has decided it wants to fall to pieces less than 2 weeks before japfest.So I need a cheap! fix Asap and as local to retford/notts :-)Thanks in advance Alex.
aleximport25 Posted May 6, 2015 Author Posted May 6, 2015 yeah mate. hes got a box which is untested, but ive got an oem lsd so to put an non lsd box in im going to need shafts and mounts as well.i dont think il be able to get it rebuilt in time. and i really didnt want to downgrade
rob_bower Posted May 6, 2015 Posted May 6, 2015 Could you not swap the gear set out of the non lsd in to the lsd?
aleximport25 Posted May 6, 2015 Author Posted May 6, 2015 ive never had a box in bits but if that's possible and fairly straight forward il do that,
Symo1995 Posted May 6, 2015 Posted May 6, 2015 Mate there's a lad box on Facebook 200 no mounts and no shafts would be spot on for you the lads name is Jordan grant he is in Swindon though but well worth the travel
aleximport25 Posted May 6, 2015 Author Posted May 6, 2015 That's a bargain but is a fair trek may be worth it if reshelling it doesn't go to plan :-)Thanks buddy
