djhasin Posted May 12, 2015 Posted May 12, 2015 Are the ignitions in the glanza s and glanza v the same? looks different but will be the same fitting or different? thanks in advance Quote
djhasin Posted May 13, 2015 Author Posted May 13, 2015 will they still fit and work properly if I was to fit it into a V? Quote
daniel_g Posted May 13, 2015 Posted May 13, 2015 What exact part of the ignition system do you want to change? Quote
5e colin Posted May 13, 2015 Posted May 13, 2015 you need to swap loom ecu dizzy coil/igniter and a few other sensors like mapsensor ait sensor Quote
Idrees Posted May 13, 2015 Posted May 13, 2015 When you say ignition what exactly are you referring to? Give me a ring if it's easier to explain on the phone. Quote
daniel_g Posted May 13, 2015 Posted May 13, 2015 The N/a ignition system is different.It doesnt have a king lead, and it doesnt have an external coil / ignitor on the firewall like the turbo cars. The actual dizzy itself isnt the same, and neither are the plugs on the engine loom. Quote
daniel_g Posted May 13, 2015 Posted May 13, 2015 What exactly are you trying to do anyway? Fit the N/a ignition system into a Glanza? Quote
djhasin Posted May 13, 2015 Author Posted May 13, 2015 Ahh sorry lads my fault.. what I was meant to say was the key ignition.. which is on the steering column.. my fault should have explained better Quote
Idrees Posted May 13, 2015 Posted May 13, 2015 Ahh sorry lads my fault.. what I was meant to say was the key ignition.. which is on the steering column.. my fault should have explained betterI had a feeling this was the case. The ignition barrels are interchangeable. Quote
