Jhandy Posted May 12, 2015 Posted May 12, 2015 Item forsale: wepr manifoldWepr decat Td04l Tial 38mm ewgCondition: in used condition. It came with the car. But had the wastegate cut off. So i rewelded the pipe back on. Has no leaks from welds. You will need new gaskets. But the wastegate has them already on it. It will come with oil feed and return. But you need your own water lines. Td04 is mint. Minimum shaft play. And doesn't smokeWastegate has a 0.8 spring in it. I only ran spring pressure. Price £ 450 delivered plus feesPics: Turbo in pic is not the one that will be suppliedPayment through paypalDelivery/contact Pm me or text 07794946529 Quote
glanzadude Posted May 23, 2015 Posted May 23, 2015 Can you PM me price on manifold and decat to south Ireland thanks Quote
Barnz74 Posted June 18, 2015 Posted June 18, 2015 Still for sale? I've got TD04 and EWG so just looking for what's left. Quote
