Ollieh17 Posted May 18, 2015 Posted May 18, 2015 (edited) 205 Black Glanza for Breaking Engine: Wepr Drag Style Turbo Kit with turbo and turbosmart wastegate(complete kit) SOLDWEPR 3" front exit(sounds beast)SOLDUnknown Fuel Pressure Reg £20 slight rust around the gauge, all lines included SOLDWalboro Fuel Pump £40 SOLD107,000km engine with new oil pump, cambelt kit and both crank seals changed Clear cambelt cover(slight crack on one of the bolt holes still attaches properly and can't see it)£30Emanage blue with ignition harness wired into a ep91 field harness.. plug and play SOLDBlue Fuel rail and injectors with new seals £50Oil cap £10 great conditionPolished Race Spec rocker £120 SOLDWhite silicone hose kit(radiator hoses, rear matrix hose, brake servo hose and both heater matrix hoses) good condition just need a bit of clean as in a engine! brake cleaner will make them mint £60Front mount intercooler with black pipes and blue silicone hoses(td04)-Core has a few bent fins but still holds boost, pipes have been painted black and 2k lacquered so have a few paint chips-£150Cleaned and painted Glanza inlet £30Complete set of engine polybushes £110Full 96 spec loom offersSpec 6 Clutch £170 plenty of life left, oe quality release bearing with under 300miles on it Cusco lightened flywheel £200 no cracks or heat marksBraided clutch line, replaces entire standard route £25 ChassisMiester r coilovers-paint is flaking off the springs and a bit rusty but all collars move and all adjusters are present and working-£450Glanza lower arms blasted and cleaned up sprayed black with super pro polybushes installed under 300miles on them £70pairAnti lift kit like new condition under 300 miles £40Cusco Strut brace front-middle bar polishes up nice ends painted black but could use a complete rub down and respray SOLDRear beam painted silver with polybushes fitted £70Adjustable panhard unknown make, recently painted tight to adjust £40New ball joints and track rod ends and droplinks with blue standard anti roll bar £60 lotstandard glanza front strut brace £20ABS removal kit, £70 good conditionFront brakes with WMS 110% disks greenstuff pads and hosetechnix braided lines, calipers sprayed blue but could do with being done again, pads and disk have plenty of life left. Calipers rebuilt under 300miles agoRear brakes with new disks bearings and pads, hose techinx braided lines replacing hole setup on the rear beam, rear calipers painted blue and resprayed £100 complete setupBrand new handbrake cables both sides £35 OtherEvo 6 recaro on glanza feet, bolts straight in but they don't slide not bad condition drivers side is mint passenger has had a rip repaired and scratches on rear of the seat £25052mm twin pillar gauge, previous person cut a hole in the bottom for some reason £30False floor(collection only) £30 subframe bolted to floor and ply screwed to this, cut out for battery to be located in the bootnew HID kit £2098 spec front bumper in 205 black, mint condition apart from hole for side exit(still have the cutout so can be fixed pretty easy) brand new from toyota glanza badge with fogs-£160Tidy glanza carpet £20Cooling panel good condition polishes up nice £25 Double 52mm Will add parts as i remember them, all standard parts are also available on request. Payment & Shipping Details: Payment through paypal(plus fees) postage can be arranged depending on item or cash on collection Edited May 20, 2015 by Ollieh17 Quote
RobSR Posted May 20, 2015 Posted May 20, 2015 Does the clutch line run from the master to the slave then? So no solid line? Got any pics? Who made it? Quote
Ollieh17 Posted May 20, 2015 Author Posted May 20, 2015 It does yeh, hel made it. Will get a pic Quote
#TIDGEY Posted May 21, 2015 Posted May 21, 2015 Free bump ( cause i never noticed this was a top mount setup and the side exit wouldnt fit onto mybottom mounted setup ... sorry Ollie ) Quote
Fozzie Posted May 21, 2015 Posted May 21, 2015 Do you have a picture of the panhard rod buddy? Are the bushes on it in good condition? Quote
Ollieh17 Posted May 22, 2015 Author Posted May 22, 2015 Ill get it off today mate!Engine, inlet fuel rail, mph convertor, gauges and deflectors sold Quote
4efteboost Posted May 26, 2015 Posted May 26, 2015 Have you got the standard glanza windscreen washer bottle and radiator expansion tank? Also have you got a pic of your oil return for the top mount kit? Quote
BirdtheV91 Posted May 26, 2015 Posted May 26, 2015 Could you pm me with your number pal I want the rear brake setup Quote
toyotatomes Posted May 27, 2015 Posted May 27, 2015 Ollie do you still have the mirrors and are they electric?Luke Quote
Xchloexxxx Posted June 16, 2015 Posted June 16, 2015 Got both headlights with indicators for sale? Quote
