anyone ever had any problems with the wiring to the map sensor? Common place for wires to brake?
Cheers
I've recently had some massive issues with the MAP sensor mate, was causing the engine to flood etc. Makesure its actually plugged in correctly, check the terminal pins are secured, as that's a common place for it to go.
Also, check the wiring loom next to the ECU, if anyones been playing around with an FCD under there, they could've bodged it & not soldered the wiring correctly, or not even soldered at all!
Let us know how you get on mate.
When I took mine off, about 4" below the sensor someone had cut it for some reason ans just wrapped it back together lol
Has never gave me any problems thoo, map sensor gone now not needed for me
