Cars booked in tommorow for a quick dyno run.
Just happened to notice wastegate screamer has dissapeared. At the moment the wastegate out pointing down and towards the dizzy..
will it be ok to run as i have no replacent.
The tuner is shut tommorow so stuck what to do..
any help would be much appriciated
thanks
Shouldn't cause an issue unless it's blasting close to the air filter or to close to plastic/wires that it could melt.
May rise the under bonnet temps slightly but wouldnt concern me greatly
when was the last time you seen it ha? id be out crusing the streets searching for it! need to turn down your justine beiber album so you can hear parts flying off :p
ahh gutted atleast it was just the screamer and not the wastegate itself! gotta be one the largest things someones lost of a starlet with out noticing tho ha!
