sayer88 Posted May 23, 2015 Share Posted May 23, 2015 Hi everyone, I'm having an annoying issue with my 96glanza, if I put my foot flat down soon as revs hit between 4500-5000rpm the car starts stuttering and spluttering but if I put foot down 1/2-3/4 it will rev round to red line no problem at all????? Any help or advise would be great thanks Dan. Quote Link to post Share on other sites
Sefton-EP91 Posted May 23, 2015 Share Posted May 23, 2015 Check all ignition components, plugs, leads, dizzy cap and rotor arm for any damage etc sounds like something is breaking down under load! check 02 sensor as well, mine spluttered and misfired under load, I replaced my 02 sensor and all was ok! Hope this helps mate! Quote Link to post Share on other sites
sayer88 Posted May 23, 2015 Author Share Posted May 23, 2015 Thanks mate I'll give that a try. Quote Link to post Share on other sites
Kate Posted June 14, 2015 Share Posted June 14, 2015 Mine has been stuttering in low revs as I slowly accelerate and I think mine is the timing so may be worth checking timing is correct x Quote Link to post Share on other sites
