Hi guys,
Hope you are well?
Looking to put 15x8 et32 alloys on an EP91 Glanza - will they fit ok? I know standard fitment is et38 and a 6.5" wheel. Has anyone tried a 15x8 et32 fitment wheel that could share some pictures - do they stick out past the arch?
These are the wheels I am looking at:
http://www.ebay.co.uk/itm/281519833889?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D281519833889%26_rdc%3D1
Thanks for your help! :thumbsup:
Edited by Anees
Thanks mate - so you think just a little rear arch roll and they should fit ok? The car is on BC Coilovers so hopefully the stiffer suspension also helps.
Would an et32 8" wide rim sit pretty much flush with the wheel arch or does it stick out past? Which I'm not keen on...
Cheers
I think that'll sit pretty flush, Wont poke. Rear may need a small roll depending on tyres. I was looking at these also - nice wheel :)
Think you'll need a roll all round, adjustable panhard rod and run some camber up front. But it's a lot friendlier on arches than many setups
